Reversing Scroll Compressor - HVAC - DIY Chatroom Home Improvement Forum
Old 08-07-2009, 05:49 PM   #1
reversing Scroll compressor
Is there anyway to reverse a scroll compressor? after installation it seems like it is running the wrong direction.
floser is offline   Reply With Quote
Old 08-07-2009, 05:53 PM   #2
Why do you say that?
hvaclover is offline   Reply With Quote
Old 08-07-2009, 06:07 PM   #3
When the contacts engage, the high side quickly heats up then cool down with seconds; then suction side gets warm instead of getting cold.
Old 08-07-2009, 06:14 PM   #4
newtech's Avatar
Rewards Points: 164
If you put your guages on it you should be able to see if it needs to be reversed. And yes you can change the direction (on a 3 phase scroll compressor) On a single phase compressor you have a different problem
newtech is offline   Reply With Quote
Old 08-07-2009, 07:30 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 2,230
A bad capacitor or mixed up wiring to the capacitor can cause that problem. Happens with cond fan motors also.
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
Compressor Replacement Lawrence Coppar HVAC 1 06-30-2009 10:50 AM
compressor replacement blues sandman64 HVAC 30 03-22-2009 08:24 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Fridge compressor convert to air compressor? jogr Appliances 1 04-24-2008 01:10 PM
