Reversing Airflow Goodman GMPN 060-3 Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-28-2012, 11:46 AM   #1
reversing airflow Goodman GMPN 060-3 furnace
Can anyone tell me how to change airflow from updraft to downflow on a Goodman GMPN 060-3?
joeya1953 is offline   Reply With Quote
Old 01-28-2012, 12:12 PM   #2
HVAC Tech/ Browns Fan
Flip the unit but need find if its able to be flip for down flow. Some units can be and some can't be flip
Tator1076 is offline   Reply With Quote
Old 01-28-2012, 12:15 PM   #3
Why do you want it change?
Old 01-28-2012, 12:22 PM   #4
reversing airflow GMPN 060-3
Was told this could be used as downflow, if I flip ( turn furnace upside down? ) does the vent fan need to be flipped so drain tube is on the bottom, anythinng else need flipping?
Old 01-28-2012, 12:36 PM   #5
Get the installer book out and will tell you how to do it
Old 01-28-2012, 12:37 PM   #6
But you may have to redo the metal
Old 01-28-2012, 12:45 PM   #7
Replaced furnace is a downflow, was old 68 intertherm, sucked gas bad, thought I'd save the earth (and $ ) and go 92% eff, bought use from serviceman, was told could be used as downflow, never installed one upside down tho,
Old 01-28-2012, 12:58 PM   #8
No manual, found on internet but wasn't real clear...never said anything about installing upside down to change airflow
Old 01-28-2012, 01:19 PM   #9
(877) 254-4729 Goodman manufacturing may help to get a book
Old 01-28-2012, 01:25 PM   #10
User manual only says multi positional. Might only mean upflow and left-right horizontal.
hvac5646 is offline   Reply With Quote
Old 01-28-2012, 01:27 PM   #11
AKA HVACTECHFW
Rewards Points: 1,208
http://www.alltemp-hvac.com/gmpn.pdf
page 22 and 23
and yes those are some of the worst installation instructions I have ever seen.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-28-2012, 01:33 PM   #12
Found a PDF says it's reversible.
But that model was a 1997 make. I'd be worried about the heat exchanger, if it isn't already compromised.
The Following User Says Thank You to hvac5646 For This Useful Post:
hvactech126 (01-28-2012)
Old 01-28-2012, 01:36 PM   #13
What read it saying to turn the draft motor around for down flow or up flow
Old 01-28-2012, 01:39 PM   #14
Most goodman heat exchangers have 20 years warranty
Old 01-28-2012, 01:43 PM   #15
AKA HVACTECHFW
what good is the warranty if you still have to pay for the labor. You dont buy a used furnace just to have to put a heat exchanger in it. And you'll be putting the same design heat exchanger in that already failed once.
IT IS WHAT IT IS
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
pro and con goodman furnace and ac leiut56 HVAC 8 07-24-2011 06:43 PM
Goodman furnace control board patz83 HVAC 7 03-14-2010 02:07 PM
Goodman Gas furnace, A/C will not run new install RCApp HVAC 5 08-04-2009 09:00 PM
Goodman furnace not starting cathyfc HVAC 1 10-05-2005 11:35 AM
