Old 01-17-2009, 03:46 AM   #1
Question
reverse the flow on FHA LP furnace?
Hi There,
I just moved into a new place recently, and it appears the airflow on my furnace is backwards. I'm guessing it was an error in the install. What appears to be the returns are blowing hot air (there are two of them), and all the registers in the floor are sucking air. Is there an easy way to reverse the fan or something?
lcplbenee is offline   Reply With Quote
Old 01-17-2009, 04:10 AM   #2
Is this a brandy new place that never had occupants before? I'd rather think you have an obstruction otherwise. It is possible for the factory to wire a blower backwards.
hychesee is offline   Reply With Quote
Old 01-17-2009, 12:41 PM   #3
Dr Heat's Avatar
A blower running backwards moves very little air. it loads up and freeweels in the housing like a car tire spinning on ice. The air will still move in the same direction.
If you have air coming out the returns and sucking in the supplies contact the installer and have him explain it.
IMHO there must be another explanation as this would be one big F... up. One or two ducts connected wrong maybe but all?
Dr Heat is offline   Reply With Quote
Old 01-17-2009, 05:49 PM   #4
JohnH1's Avatar
It sounds like the oridginal furnace was a counter flow and someone installed a upflow. Most furnaces cannot be flipped to work as counterflow but some can. What is the info on the furnace.
JohnH1 is offline   Reply With Quote
Old 01-17-2009, 06:34 PM   #5
hvaclover's Avatar
I smell a troll.
There is a way but first tell me how Long you have lived in the home.
Brand and seial number would be helpful
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
Filtering an up flow furnace without filter grills Rookietinner HVAC 1 11-20-2008 12:20 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
