Reusing Cellulose Insulation/humidity Absorbtion - HVAC - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 10:08 AM   #1
Rewards Points: 79
Reusing cellulose insulation/humidity absorbtion
I have a about 40 large bags of cellulose insultion I've taken out of my attic so I could replace some knob and tube wiring. Currently they're sitting in my backyard since I don't really have any other convenient place to put them. Is there any reason I wouldn't want to reuse the stuff when it's time to blow it back into the attic? At the rate I work on projects it could be out there for a month or more and it's damn humid this time of year. It's just shredded newspaper isn't it? Seems like humidity absorbtion could be a problem but then again it might not be any different in a hot humid attic.
Ptron is offline   Reply With Quote
Old 08-01-2010, 10:51 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,236
Should be okay as long as they are sealed tight and no rain or rodents get into them.
Old 08-01-2010, 12:04 PM   #3
Rewards Points: 79
Hmm. Well, I have them in a place that is pretty protected from rain but they aren't really sealed tight. They're just tied off with the built in flaps which leaves openings. I suppose I could tie them off better with twist ties or something. Maybe that would be a good idea anyway to keep bugs and stuff out.
Old 08-01-2010, 12:24 PM   #4
Hvac Pro
yuri's Avatar
They should be sealed in large orange leaf plastic garbage bags.
Old 08-01-2010, 01:49 PM   #5
An old Tradesmen
Rewards Points: 7,278
Is your attic sealed? If not, then your attic has as much moisture in it as the outside air.
Old 08-01-2010, 02:10 PM   #6
Rewards Points: 79
Good point. Ok. I will seal them a bit better, hope they don't get critters and try to reuse when the time comes. Thanks.
Insulation - Cellulose vs. Icynene meth Building & Construction 25 12-17-2014 10:04 PM
cellulose insulation life expectancy jjmch Roofing/Siding 3 04-11-2010 10:40 PM
Blowing In Cellulose Insulation - Need Advice gma2rjc General DIY Discussions 26 04-13-2009 08:13 PM
Cellulose insulation as mulch gmatov General DIY Discussions 7 06-23-2008 06:45 PM
