Return Vents High Or Low - HVAC - DIY Chatroom Home Improvement Forum
Old 07-22-2011, 09:50 AM   #1
return vents high or low
With a high heat load in factory setting should the return vents be high, along with the supply registers. It seems I am not getting total room exchange. Seems like the cold air is being circulated before it even drops to the floor.
johnnyg is offline   Reply With Quote
Old 07-22-2011, 10:11 AM   #2
Experienced
Jackofall1's Avatar
Welcome Johnnyg, to the best darn DIY'r site on the web.
Not sure what you are referring to when you say factory settings?
Is the high heat load in a house?
Mark
cold return and heat vents in basement gaetz1 HVAC 1 02-24-2011 07:56 PM
Moving Return Vent Upstairs Rowhousefix HVAC 0 08-11-2010 02:39 PM
Return Air Vents stubits HVAC 149 04-21-2010 04:50 PM
question on return duct familyman HVAC 13 01-25-2009 11:05 AM
Moving supply and return vents N8E HVAC 1 09-30-2008 10:25 PM
