Return Vent Size Change - HVAC - DIY Chatroom Home Improvement Forum
Old 10-24-2009, 06:09 PM   #1
return vent size change
I am re flooring my family room and thought it an opportunity to replace the original 15.5" x 10" vent with a smaller nice looking vent cover. Is there a reason not to do this?
The house was built in the early 1950s with gravity heat system, It is now a high efficiency forced air system.
philip18 is offline   Reply With Quote
Old 10-24-2009, 06:36 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Is this the only return?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 10-24-2009, 06:37 PM   #3
Houston204's Avatar
Rewards Points: 556
An undersized return can damage equipment. It is usually a bad idea to decrease the return size.
Houston204 is offline   Reply With Quote
Old 10-24-2009, 06:44 PM   #4
An old Tradesmen
Rewards Points: 6,464
Yep.
Got to watch decreasing return size.
Could harm equipment. Make lots of noise through the grille. And not be able to heat the house as well(as in not reach set temp of stat).
Old 10-24-2009, 06:53 PM   #5
It is the only one in a room 13.5 x 17.5. I guess the consensus is, it's a bad idea.
Even considering the fresh air intake added to the outside?
Old 10-24-2009, 06:56 PM   #6
An old Tradesmen
You can't put air into a room if you don't have a way for air to get out of a room.
So the fresh air intake, isn't providing a path for air to leave that room.
Also. With a fresh air intake. If you remove, or reduce return air from rooms. Due to the house leaking air out of it. You will increase the amount of fresh air that intake brings in. And increase your heating bill.
Old 10-24-2009, 06:58 PM   #7
Rewards Points: 560
Again, Is this the only return?
Old 10-25-2009, 12:18 AM   #8
Yes,if anything, without a pros advice make it larger ,keep it the same,don't make it smaller.
dash is offline   Reply With Quote
Should I have let the ac guy close off a return? windowman3 HVAC 4 09-13-2009 09:23 AM
Help with return and supply size XHornet85 HVAC 9 09-17-2008 12:13 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 11:40 PM
Running network wiring in a cold air return vent? mcvane Electrical 26 04-19-2007 08:52 AM
