Return Vent In Laundry Room? Is It Possible? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-09-2011, 02:00 PM   #1
Question
Return vent in laundry room? Is it possible?
Hi,
Im renovating my bottom level of my split level home. The house previously had a large family room, a 1/2 bathroom/laundry room and a closet. The return vent for the HVAC is in the closet (which is right next to the bathroom/laundry room). I would like to move the washer dryer to the closet area and make the bathroom a full bath. I would like to know if it is possible to place the washer and dryer in the "closet" considering I have the return vent in there. I am not sure if a return vent is supposed to be in a closet either. Let me know your thoughts. I do not want to place a laundry room where the return vent is if it poses a danger. Is a return vent necessary on the bottom level? Can I eliminate it? Is there any books that I can read on how to do this and what is the appropriate and safe way to do this?
Thanks for any advice/thoughts in advance.
jmcphers is offline   Reply With Quote
Old 08-09-2011, 02:29 PM   #2
Its not a good idea. In fact it is against code where I live to put a return in the laundry or bathroom. Can the return be moved to the ceiling?
Master of Cold is offline   Reply With Quote
The Following User Says Thank You to Master of Cold For This Useful Post:
jmcphers (08-09-2011)
Old 08-09-2011, 02:41 PM   #3
Do you think it can be moved to an area under a staircase? Or should the vent be open to the family room it it were to be installed in the ceiling?
Old 08-09-2011, 03:19 PM   #4
Rewards Points: 6,652
You need to draw out a floor plan, and if available, use the architectural drawings from when it was originally built. Also, before making the changes, you may be required in order to pull the permits, a drawing for plumbing, hvac, electrical, and any structural changes (ie walls being moved or removed). Post a drawing of the space showing current hvac layout, and you should be able to get better help in what you are wanting to do.
Tags
gas dryer , hvac , laundry
return air vent swoop HVAC 0 06-08-2011 08:46 PM
Laundry Room Vent: slope up - then down LogDog Plumbing 3 12-31-2010 05:59 PM
converting laundry room to bathroom brandisophie Plumbing 8 11-07-2010 02:10 PM
dehumidifying laundry room rocketdoctor Appliances 4 10-21-2009 02:08 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
