Return Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2008, 05:14 PM   #1
return vent
my room is cold on the far side of the house what do u have to do in order to put in a cold air return vent???
chmemakowski7 is offline   Reply With Quote
Old 10-27-2008, 05:18 PM   #2
the Musigician
DangerMouse's Avatar
is there a heat register in the room? but no cold air return?
DM
Old 10-27-2008, 07:14 PM   #3
return vent
yes there is a heat vent but no return vent
Old 10-27-2008, 07:21 PM   #4
the Musigician
is there sufficient heat coming from the register? i don't think a return air duct will make that much difference.
how well is that area insulated? windows all caulked and sealed?
DM
Old 10-27-2008, 08:51 PM   #5
What can I find here?
Winchester's Avatar
Rewards Points: 150
Two returns added to my father-in-laws main living area made a night and day difference from what he tells me. You certainly do need that air flow from what I've experienced.
I've read that you should never have a return on an exterior wall. In any of the homes I've owned, the cold air return was panned in a floor joists back to the return of the furnace. All depends on your setup though. (i.e. - 1st floor, 2nd floor, basement, crawlspace, ect.)
Winchester is offline   Reply With Quote
Old 10-27-2008, 09:26 PM   #6
You can use a transfer grill if running a return to the room can't be accomplished thru a basement or crawl space.
Do the other rooms have a return each, or is there one central return for the the whole home.
Older home used out side wall return placed under windows. Of course the older furnace threw air in excess of 160*F in huge slow moving volumes thru larger then today's ducts and blanketed the rooms more thoroughly. The idea was the cold air return would cause "waterfall" down the window of heated air.
hvaclover is offline   Reply With Quote
Old 10-28-2008, 07:24 AM   #7
An old Tradesmen
Rewards Points: 6,928
Is the door to this room under cut.
Did the home originally have hardwood floors, and then get carpet, that covers the under cut.
Does the room get more air with the door open then closed. If not, a return won't help.
Returns are not panned to the supply. If it was, it would then be a supply.
Returns are panned back to the return duct, or drop.
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 01:43 AM
cold air return vent height. is there code? DangerMouse Building & Construction 4 10-07-2008 01:53 PM
HVAC return vent location question fatboy HVAC 1 03-10-2008 08:56 PM
Running network wiring in a cold air return vent? mcvane Electrical 26 04-19-2007 07:52 AM
