Return Register Size For 16" Flex - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-14-2008, 05:18 PM   #16
Originally Posted by beenthere View Post
Guess you wouldn't like the 6" pipe that has 2000CFM moving through it.
This pipe runs 300', and has a 100 hp blower on it.
It also travels several foot into a treatment tank.
And runs at 5PSIG static presure.
If you got the Horse Power, you can move as much air as you want through a small pipe.
O P. How much air do you want this 16" flex to move.
That was my point exactly.
Hvaclover was having one of his slow days and didn't get it...
We love you hvaclover...just giving you a bad time....
Air guns move a lot of air at high velocity. I made one once that had a two stage air dump. One at the bottom and one half way up. The one half way up would dump the air once the arrow had passed that point. Kind of like an accelerator.
I did this as a science project in 8th grade with my dad. The physics teacher thought it was cool but the school thought it was to dangerous for a show and tell.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-14-2008, 06:35 PM   #17
How many 50 tons systems do you know use 16" flex.? That was the point.
Let's stay on topic shall we?
hvaclover is offline   Reply With Quote
Old 11-15-2008, 11:13 AM   #18
1610 CUB's Avatar
Rewards Points: 150
Originally Posted by hartkem View Post
What size return register do I need for 16 inch flex. There will be one register centrally located in the hall way.
It looks like this 16" flex return is either in the floor or is it in the wall. Now if its in the floor a 16"sq hole should work. (16X16=260sq/in) Good for 3 ton at 800cfm.
But if its in the wall....... it will take a 3.5X70 hole in the wall cavity
1610 CUB is offline   Reply With Quote
Help with return and supply size XHornet85 HVAC 9 09-16-2008 11:13 PM
Return Air Grille Size...? ssporty21228 HVAC 4 08-17-2008 10:00 PM
return duct size dave150 HVAC 4 02-20-2008 02:19 PM
What size should cold air return grille be? AllGoNoShow HVAC 1 02-27-2007 03:48 PM
