#1 |
Return Register Size for 16" Flex
What size return register do I need for 16 inch flex. There will be one register centrally located in the hall way.
#2 |
600 sq in should work (depending on the cfm's in the flex duct).
Keep in mind that it is not about size, it is about cfm's pushed through. A 16 flex can have anywhere from 0 to 10,000 cfm's or more. Average would be about 1800 cfm's. If you want to do it correctly (and don't have the tools) you should total the cfm of your furnace, divide the total inches of duct work, and multiply that times the volume of each duct to get an idea of how much is flowing through each duct. Then you could find a reasonable idea of how much air is going through the 16. Then you could get a more accurate idea of how big the return should be. It is usually better to go bigger if in doubt. Starving a furnace for return air is a good way to shorten it's life and decrease it's efficiency.
My idea of a perfect day: No where to go and all day to get there. |
#3 | |
Return Register Size for 16" FlexQuote:
Marv 10,000 cfm is 25 tons of cooling. You won't get that thru 16" flex pal
Just slow, not stupid. |
#4 | |
Plus it would be really windy.
#5 | |
It has never been done nor would it ever be considered.
#6 | |
Size of return is all dependent on the output of the furnace. If you look at the other end of my example I had 0 CFM. In that case there would be no need for a return, right?
#7 | |
Sorry but it was just too much for a layman not to accept at face value.
#8 | |
I tell my paramedic students to never start in intraocular IV. That gets them thinking and some figure it out and some don't. There is no such thing as in intraocular IV since that means sticking a needle in the eyeball and running some fluid or drugs in there. DON'T BLINK, DON'T BLINK!!!!!!!
#9 |
oops, did I do that!
Flex for a return...not the best choice.
#10 |
10,000CFM at 7,500FPM = 16" used only to suck up small children and pets. Some industrial application's may apply.
#11 |
And duct cleaning....
#12 |
We call that a shop vac on steroids.
#13 | |
#14 | |
#15 |
An old Tradesmen
Guess you wouldn't like the 6" pipe that has 2000CFM moving through it.
This pipe runs 300', and has a 100 hp blower on it. It also travels several foot into a treatment tank. And runs at 5PSIG static presure. ![]() If you got the Horse Power, you can move as much air as you want through a small pipe. O P. How much air do you want this 16" flex to move. |
| Display Modes | |
| Help with return and supply size | XHornet85 | HVAC | 9 | 09-17-2008 12:13 AM |
| Return Air Grille Size...? | ssporty21228 | HVAC | 4 | 08-17-2008 11:00 PM |
| return duct size | dave150 | HVAC | 4 | 02-20-2008 03:19 PM |
| What size should cold air return grille be? | AllGoNoShow | HVAC | 1 | 02-27-2007 04:48 PM |
