Return Grille - HVAC - DIY Chatroom Home Improvement Forum
Old 07-11-2006, 05:16 PM   #1
return grille
I need to replace my upstairs return grille. I'm remodeling and my current one probably has 5 coats of paint on it. Pretty ugly. I can't find the grille size anywhere though. The opening is 14x19. The grille that is on there measures 15 3/4 x 21 3/4 end to end. Is this an odd size or something? thanks
farrington135 is offline   Reply With Quote
Old 07-12-2006, 08:11 AM   #2
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
14x19? Wow, sounds like what you've got is a commercial grade return. You may have to look for a replacement under commercial, like these
http://www.atlantasupply.com/swscrip...EST_ID=CSTKDET
J187 is offline   Reply With Quote
Old 07-20-2006, 09:31 PM   #3
coolmen's Avatar
14 x 20 is what is needed to cover your hole.siply take the grill offf the wall/ceiling go to hvac supply house near you,dont know if home depo carrys that size. do you have a grainger near by? or find the next size higher like 16 x 20 or 14 x 24, you wont hurt the system
coolmen is offline   Reply With Quote
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 01:43 AM
What size should cold air return grille be? AllGoNoShow HVAC 1 02-27-2007 03:48 PM
Air Conditioning air return hiss during startup craig_dot_net HVAC 2 10-10-2006 08:27 AM
Cold Air Return near ceiling or floor? jakobus HVAC 3 07-21-2005 10:54 PM
