Old 08-15-2011, 01:25 AM   #1
JJboy's Avatar
Return Filtr Grille
I made this table, can anyone confirm these values?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-15-2011, 05:13 AM   #2
An old Tradesmen
Return Filtr Grille
Those numbers are correct, as long as you remember that they are the AK/free area numbers, not the grille size numbers.
EG: A 20X20 filter grille, is 400 sq in total, but has a AK/free area of only 276 sq in/1.917 sq ft. So at 575 CFM it has a air velocity of 300 FPM, at 767 CFM it has a air velocity of 400 FPM.
Go to Hart&Cooley's website, and download their register/grille specs/tech guides.
Old 08-15-2011, 12:53 PM   #3
JJboy's Avatar
Return Filtr Grille
Thanks Beenthere
http://www.hartandcooley.com/Librari...?download=true
Noises (singing and rumble) at main return grille John_W HVAC 1 01-28-2010 05:40 PM
Loud air return grille - suggestions? chrisd HVAC 6 02-17-2009 04:25 PM
Return Air Grille Size...? ssporty21228 HVAC 4 08-17-2008 11:00 PM
What size should cold air return grille be? AllGoNoShow HVAC 1 02-27-2007 04:48 PM
return grille farrington135 HVAC 2 07-20-2006 10:31 PM
