Return Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 07-24-2008, 09:10 AM   #1
return duct
just trying to get a idea of about how much return air is needed for 1-4 ton systems
heatdude is offline   Reply With Quote
Old 07-24-2008, 05:11 PM   #2
Registered User
Termite's Avatar
Too general of a question. It depends on supply duct size, quantity, length, house size, etc.........
Old 07-26-2008, 09:53 AM   #3
oops, did I do that!
Way too general. At least 400-1600cfm. Return air is pretty much dependent on the Local or State Mechanical Codes, per sq. in. per cfm..
Velocity is not equal to supply velocity.
General question=general answer.
8 Ball is offline   Reply With Quote
Old 08-01-2008, 02:16 PM   #4
"just trying to get a idea....."
A rule of thumb frequently used is: "the supply air should be adjusted to obtain a minimum of 400 cfm per ton". SO, return air is, in a rule of thumb way, also 400 cfm per ton.
rosehillraymond is offline   Reply With Quote
Water in (and around) return duct kennelm HVAC 6 06-18-2008 07:13 AM
Should I seal return air duct? phareous HVAC 1 11-13-2007 12:14 AM
Humidifier in Return duct TurningColorz HVAC 2 10-29-2007 06:59 PM
