Return Drop Sizing - HVAC - DIY Chatroom Home Improvement Forum
Old 10-09-2012, 06:24 PM   #1
Return drop sizing
I need to get a furnace replaced and I've had a bunch of estimates. Some want to replace the drop and others done. The ones who don't are not being considered. I need enlarged sized ductwork since I have a 80k BTU furnace need and a 3ton AC need. In any case, the ductwork is sized too small and needs to be enlarged.
My question is, for a furnace/AC need as I have, and for a 16x25 filter frame, what is a properly sized return drop? Some places want to replace it with a 20x14 and others want to use a 20x8. One wants to use a 22x10. These numbers all all over. Are they too small? I have some numbers in my head, and none of the estimates jive with what I understood the need to be.
agibby5 is offline   Reply With Quote
Old 10-09-2012, 06:48 PM   #2
An old Tradesmen
Rewards Points: 7,388
22X10 is ok.
What size is your old furnace.
Old 10-09-2012, 08:20 PM   #3
144 squareinches per ton.. equals-432square inches minimum for the return
Nickhvactech is offline   Reply With Quote
Old 10-09-2012, 08:36 PM   #4
An old Tradesmen
I think your thinking of the return grille. 144 sq in per ton.
A 10X20 sheet metal duct will move 1200CFM at a friction rate of .042" per 100 foot of total equivalent length, at a velocity of 864PM, which is more then acceptable.
The Following User Says Thank You to beenthere For This Useful Post:
Nickhvactech (10-09-2012)
Old 10-09-2012, 08:41 PM   #5
I understand the question now!! Reading too quickly
Old 10-10-2012, 08:29 AM   #6
At this point, my next question is:
Is one 16x25 filter frame inadequate??
Old 10-10-2012, 03:11 PM   #7
An old Tradesmen
16X25 return air filter grille, or 16X25 return air filter bracket.
for a bracket, the velocity is 433FPM, which is ok, a little higher then preferred. For a return air filter grille, its too small.
3Qs -Drop Main Return, Backup Drain, Coil Cleaning allthumbsdiy HVAC 6 09-05-2012 12:35 PM
Basement return air ducting - flex or metal? BasementVirgin HVAC 5 10-29-2009 12:01 PM
return sizing sixty7flh HVAC 4 09-16-2009 11:35 AM
Drop Ceiling Prices? bengbrewer Remodeling 8 03-18-2009 02:00 PM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 08:29 AM
