Return Air Velocity - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 04:50 PM   #1
Rewards Points: 264
Return Air Velocity
I there an ideal FPM number for residential return air velocity?
I read once that Manual D return air maximum velocity is 700 fpm. Not sure if that is correct. Is there a minimum?
I also believe that I read that the lower the velocity, the better the filter works. And the higher the velocity, the more air movement noise and lower filter efficieny.
Can the velocity be too low?
What FPM range do you normally try to stay within?
Earnie is offline   Reply With Quote
Thinking of relocating Basement return, good idea? Windwalker HVAC 0 12-19-2010 12:49 PM
Moving Return Vent Upstairs Rowhousefix HVAC 0 08-11-2010 03:39 PM
Should I have let the ac guy close off a return? windowman3 HVAC 4 09-13-2009 09:23 AM
return air honola HVAC 11 08-13-2009 08:41 AM
Enough Return Air? mjbxx HVAC 3 02-12-2009 07:26 PM
