Return Air Size - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 08:48 PM   #1
Return Air Size
I am finishing my basement and want to make sure my return air is done right.
I have put in 5 6" duct extensions.
I know that what I put out has to equal what I pull back.
So the cross sectional area of these five new ducts is 140.
So the questions I have are really about how many wall cavities I need. I have been wondering if I need 3: 3 wall cavities each with a cross sectional area of 3.5 * 16 for a total of around 160.
Also for the ducts that connect to the wall cavities to the existing cold air return square duct work, I am not exactly sure how many I need.
Thanks for any help and input.
b
bkeech is offline   Reply With Quote
Old 01-11-2010, 05:10 AM   #2
An old Tradesmen
Rewards Points: 8,234
Probably 3-8" or 4-7"
Old 01-11-2010, 03:40 PM   #3
Thanks.
So a wall cavity for each of these also?
Old 01-11-2010, 03:52 PM   #4
An old Tradesmen
A 2X4 cavity, will only pull about 140CFM.
So add up what your supply CFM is. And use as many cavities as you need to equal that. And a cavity should have its own individual duct back to the trunk.
Need advice on odd cold air return size angrydot HVAC 1 12-12-2009 01:23 PM
What Size are Return Ducts Usually K.M.G HVAC 33 09-26-2009 07:08 PM
a/c return size bmancanfly HVAC 2 09-03-2009 07:16 PM
Help with return and supply size XHornet85 HVAC 9 09-16-2008 11:13 PM
Return Air Grille Size...? ssporty21228 HVAC 4 08-17-2008 10:00 PM
