Return Air Return - HVAC - DIY Chatroom Home Improvement Forum
Old 12-15-2012, 10:59 PM   #1
Rewards Points: 33
Return Air Return
How important is it I have return air on my second floor?
How important is it that the return air is 'away' from the supply vent?
What's like... the best distance to keep the supply from the return?
Thanks in advance
Ghengisconrad is online now   Reply With Quote
Old 12-16-2012, 12:57 AM   #2
Rewards Points: 1,192
Supply register on outside wall,return on inside wall.You need return airflow.
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
Ghengisconrad (12-16-2012)
Old 12-16-2012, 06:14 AM   #3
Items wanted: Time
Rewards Points: 150
Second floors are chronic problem spaces in regards to temperature. Properly designed duct and properly sized equipment are critical when trying to maintain consistent temperature throughout a home.
NiNe O is offline   Reply With Quote
Old 12-16-2012, 09:28 AM   #4
Rewards Points: 33
what if the existing wireing, finish work, and overall structure of the house makes it extremely difficult to put the return on the opposing inside wall, but very simple to put it 12 feet away in the corner of the room?
Its a half story btw.... 1 outside wall, 2 'attic' walls angling down to the slope of the roof, and one inside wall....
Old 12-16-2012, 09:56 AM   #5
Experienced HVAC Tech
HVAC1000's Avatar
Is it a loft style second floor where it is open to a large open space on one side?
HVAC1000 is offline   Reply With Quote
Old 12-16-2012, 10:11 AM   #6
Rewards Points: 33
I'm sorry, I don't quite understand the question.
It is what we call a 'half story'; where the ceiling follows the pitch of the roof on the two opposing sides of the 2nd floor. We have two dormers in the middle which is where the bathroom and stairs are respectivley. On either side of the bathroom are two bedrooms.
The bedrooms are what I am concerned installing return air in.
Each Room has an outside wall where the supply is already installed directly under a the window. Then opposing the outside wall is the inside wall. The two adjacent walls are at an angle following the roof untill they disappear into the ceiling to create the pitch where the attic is.
Old 12-16-2012, 10:11 AM   #7
Rewards Points: 33
yeah, like this
http://www.google.com/search?um=1&hl...56%3B600%3B450
Old 12-16-2012, 10:12 AM   #8
Rewards Points: 33
also, like this
http://www.google.com/imgres?q=half+...w=1013&bih=929
Old 12-16-2012, 10:47 PM   #9
Rewards Points: 54
Had returns put in every bedroom upstairs. Each room is a better more comfortable place.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Do I need this cold air return, pictures shown steffen707 HVAC 8 01-18-2012 02:39 PM
Looking for return noise help BlueNote HVAC 1 06-11-2011 10:06 PM
Moving Return Vent Upstairs Rowhousefix HVAC 0 08-11-2010 02:39 PM
Should I have let the ac guy close off a return? windowman3 HVAC 4 09-13-2009 08:23 AM
return air honola HVAC 11 08-13-2009 07:41 AM
