Return Air Requirements - HVAC - DIY Chatroom Home Improvement Forum
Old 10-11-2009, 11:41 AM   #1
Question
I Am installing an Goodman 69k btu furnace in my home, I am wondering what would be the standard return air requirements, I will be cutting out the sill plate and floor on a partition wall i am not sure if one stud span will be enough. I will be using a regular filter.
Thank You very much for any input
f4urak is offline   Reply With Quote
Old 10-11-2009, 11:52 AM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Is this with ac too?
If so what size ac are you installing?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 10-11-2009, 12:02 PM   #3
There is no A/C, the output of furnace should be around 600 cfm i believe, I live in mild climate Portland Oregon.
Old 10-11-2009, 12:07 PM   #4
Rewards Points: 560
You are going to need approx 140 sq in
Are you on 2x4 or 2x6 studs?
Even two wall chases are not enough but three would do it with 2x4 walls.
Old 10-11-2009, 12:13 PM   #5
Ok Thank you very much for your help i will pull return air from 3 rooms with 2x4 studs.
Old 10-11-2009, 12:18 PM   #6
Rewards Points: 560
Just remember that you can't pull from kitchens, baths and garages
If you are goint from other rooms how are you connecting between the room and furnace?
Good luck
Old 10-11-2009, 12:42 PM   #7
i was going to go from den, living room and bedroom. from the den i was going to pan in a joist span in the basement and for the other two i was going to use 8" flex duct, its a pretty short distance less than 10 feet. What size do you think should be the main return trunk running down to the furnace?
Old 10-11-2009, 01:08 PM   #8
Rewards Points: 560
I think with that design you should be fine
Old 10-11-2009, 01:16 PM   #9
What size should the main trunk running to the return on the furnace be?
Old 10-11-2009, 01:27 PM   #10
Rewards Points: 560
Into the side of the furnace I would put a filter rack of 14x20 and then transition down to 20x8
Old 10-11-2009, 01:31 PM   #11
ok i think i have a pretty good plan on the duct. For my natural gas line, where should i put the inspectors test port? I believe it should go between the appliance shut off and the meter. When the inspector test the system do they want a cap on the nipple into the furnace or are they only interested in testing from the shut off valve to the meter?
Old 10-11-2009, 01:56 PM   #12
as seen on tv
Rewards Points: 150
I would look at the furnace data see how many cfm that furnace produces on low speed first. Then design my duct from there. Undersized duct will give you problems.
qbert is offline   Reply With Quote
Tags
duct sizing , ductwork , return air , return vent hvac basement
Basement return air ducting - flex or metal? BasementVirgin HVAC 5 10-29-2009 12:01 PM
Should I have let the ac guy close off a return? windowman3 HVAC 4 09-13-2009 08:23 AM
return air honola HVAC 11 08-13-2009 07:41 AM
Enough Return Air? mjbxx HVAC 3 02-12-2009 06:26 PM
