Old 01-08-2010, 01:46 PM   #1
Return Air with Portable Heat Pump
I have a Haire 9500 BTU portable heat pump that I use in my insulated garage. The back of the unit has two 5" hoses. During A/C usage, as the manual states, they are both vented out of the garage. The manual does not give instruction on how they should be used during heating. I have been running the exhaust hose out as normal with the intake pulling return air from inside the garage. The unit keeps the garage at 62-65F when outside air temps are 10's and 20's.
Is there greater heat transfer capability with the air intake coming from outside (both hoses vented outside) or am I better off the way I'm running now?
EDIT: After reading the manual of a similar unit, it requires both hoses be vented outside. Why Haier doesn't mention this in their manual is beyond me.
Peace,
Mark
guitarnut is offline   Reply With Quote
Want to replace heat pump. brewmastr HVAC 12 12-31-2009 11:27 AM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 04:23 AM
Ductless Heat Pump for Garage?? brittlediabetic HVAC 25 04-23-2009 03:28 PM
Please answer this question about my Carrier Heat Pump... jifmom HVAC 4 02-20-2009 12:38 PM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
