Return Air Locations? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-10-2011, 08:57 AM   #1
return air locations?
I am installing new ductwork in a second floor,it is still wide open, I tore my roof off and added a full second floor. All work is from above I am in ontario, I have had heat loss calcs, and ducting design done. I am using open web floor trusses not joists, so my returns are actual (6x12) ducts. right now the designs show returns in the bedrooms installed low on the walls. There are 4 bedrooms, 3 are around 10'x12' with a 40x40 window facing south in each one. they are being supplied with a 5" round with a 4x10 grill directly under each window. Right now the designs show returns installed low on the walls with a 6x10 grill. what is the best way to get a 6x12 duct into a wall cavity? should I get a reducing 90 6x12 to 3.5x14 and turn it up into the wall or could i run past where I need to turn up block end then cut a slot in the floor where the wall will be. or could i just put them on the floor?
dhubz is offline   Reply With Quote
Old 02-10-2011, 09:06 AM   #2
Experienced
Jackofall1's Avatar
No I would not put them in the floor.
You don't need that size duct in the wall, the grill is that size to increase face area of the grill, to decrease face velocity allowing quieter operation. The standard wall cavity or 12.5 x 3.5 is adequate for RA.
To improve the effeciency of the system you should be putting what is known as high and low wall return air registers, high in the summer/AC season and low in the winter/heating season, naturally the grills have to have operators on them (like a wall mounted heat grill) to the selection can be made from season to season.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
dhubz (02-10-2011)
Old 02-10-2011, 10:41 AM   #3
Thanks,
looking at my layout again, i am going to have to branch off the 6x12 to pickup the actual wall location. is a 5" sufficient then i will transition to a stack 90 to pick up the cavity with a high and low return. The open web trusses are handy for somethings and a pain for others.
Old 02-10-2011, 10:45 AM   #4
Experienced
Jackofall1's Avatar
Provide the largest opening possible, between the sub-floor and the wall cavity, just cut the sill plate and subflloor above the horizontal run. Installers also line the perimeter of the wall openning with sheet metal, to help cap the drywall off.
Mark
Old 02-10-2011, 03:11 PM   #5
MikeKy55's Avatar
Rewards Points: 254
This is in my basement, but it is one way of using stud cavities for return air. I used insulfoam between the studs and wall and then put 6mil plastic over the drywall side. Cut the section of top plate out.
MikeKy55 is offline   Reply With Quote
Old 02-10-2011, 05:51 PM   #6
An old Tradesmen
Rewards Points: 6,876
Floor returns are fine. Don't know if a 5" round supply for those bedrooms will be enough though.
How many CFM did they say you need to those rooms.
Moving Return Vent Upstairs Rowhousefix HVAC 0 08-11-2010 02:39 PM
question about cold air return locations ponch37300 HVAC 4 01-11-2010 08:56 AM
Should I have let the ac guy close off a return? windowman3 HVAC 4 09-13-2009 08:23 AM
return air honola HVAC 11 08-13-2009 07:41 AM
Enough Return Air? mjbxx HVAC 3 02-12-2009 06:26 PM
