Return air grilles w/filters
I have a HVAC system with two return air grilles, the filter is located under the unit which is in a wall cabinet. I would like to replace the grilles with the types of grills that accept filters, can I do this without worrying about air flow restriction? If I do this, can I remove the main filter under the unit?
Thanks! |
What size system is it.
What size are the holes in the walls. When the air filter is in the grille. The grille usually needs to be bigger. |
| All times are GMT -4. The time now is 11:53 AM. |
