Return Air Grille - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2008, 09:43 PM   #1
Return Air Grille
So this may be an easy question, but I don't know the answer. I have two air vents in my living room. I painted the living room and removed the return air grilles. I bought two new ones, but am not sure which way the air should flow...up or down. Logically i can see advantages to each. Is there a right way?
brucetackett is offline   Reply With Quote
Old 01-14-2008, 10:18 PM   #2
If majority of your furnace uses heat cycles and these are Floor Level "heat out" vents, then install the vents to blow the air "down". Thus, bouncing the hot air off the floor - before it rises to the ceiling.
If the majority of your system uses AC cycles and these are Floor Level "cool air out" vents, then install the vents to blow the air "up". Thus, arching the cold air up to the ceiling - before it settles to floor level.
If this is Floor Level "air intake vents", then its vent fin direction doesn't really matter. Same zone of air is sucked in - regardless of its cover fin direction. For better visual appearance, I would re-install the cover with the vent fins facing DOWN - so people walking by the vent cover can't see inside the vent chamber.
If this is Ceiling Level "air intake vents", then its vent fin direction doesn't really matter. Same zone of air is sucked in - regardless of its cover fin direction. For better visual appearance, I would re-install the cover with the vent fins facing UP - so people walking by the vent cover can't see inside the vent chamber.
Hope this helps...
Spike99 is offline   Reply With Quote
Old 01-15-2008, 10:12 AM   #3
Thanks, Spike. Your response certainly did help. It's a ceiling level, so I guess I'll do what looks better. Thanks again.
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 08:29 AM
Air return through vented doors yam HVAC 7 08-22-2007 11:37 AM
What size should cold air return grille be? AllGoNoShow HVAC 1 02-27-2007 03:48 PM
return grille farrington135 HVAC 2 07-20-2006 09:31 PM
