Return Air General Questions - HVAC - DIY Chatroom Home Improvement Forum
Old 10-07-2011, 02:22 PM   #1
Rewards Points: 640
return air general questions
Alright just some general education questions for me to undestand better why things are done certain ways
1) Shouldn't the return velocity be lower then the supply? wouldn't a lower velocity help make the filter system work better and not pull smaller particles forcefully through the filter?
2) Why are return trunks generally smaller then the supply plenum's total area? wouldn't you want to follow something like I asked about in #1?
if these are correct or good ideas, why does it seem like returns always have such a small total square area?
BlueBSH is offline   Reply With Quote
Old 10-07-2011, 08:41 PM   #2
An old Tradesmen
Rewards Points: 7,332
because somewhere along the line. installers started to think that since the return is a negative pressure, it does have as much of a resistance to flow in the return duct.
Old 10-07-2011, 08:46 PM   #3
biggles's Avatar
it also pulls from any place thru louvered door across rooms,up stairs cases ducted unducted and the best place to mount the stat at eye level to control a space with the return air
Looking for return noise help BlueNote HVAC 1 06-11-2011 10:06 PM
Various A/C questions - return vents, leaking air in unit, hot upstairs... PolishPaul HVAC 4 09-02-2010 01:05 PM
Moving Return Vent Upstairs Rowhousefix HVAC 0 08-11-2010 02:39 PM
question on return duct familyman HVAC 13 01-25-2009 11:05 AM
some random, general plant questions joeyboy Landscaping & Lawn Care 7 11-30-2007 06:34 PM
