Return Air Filter Grille - HVAC - DIY Chatroom Home Improvement Forum
Old 08-20-2011, 01:19 AM   #1
i have a return air duct grill that needs replacing. i measured the outside of the grill and it is exactly 22 x 22. am i correct in measuring the grill on the front outside or do i need to measure it on the frame somewhere? i noticed that 22x22 return air grilles are not to popular (chickens teeth type) so that began me to wondering if i measured it on the right place. this house of my friends is about 1800 heated space which seems a bit big for a 20x20 return air duct volume. can anyone tell me how to measure a return air grille if i am doing it wrong?? i would name my next kid after you if you advise me correctly....i am 60 years old so i dont think you have to worry with me getting a girlfriend still fertile...LOL...but i look anyway...
maxtor is offline   Reply With Quote
Old 08-20-2011, 01:54 AM   #2
JJboy's Avatar
Check this site.
http://www.hartandcooley.com/Product...diffusers.aspx
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-20-2011, 05:33 AM   #3
did you look at this site before you suggested it?
did you look at this site before you suggested it? i didnt see anything
pertinent to my question. maybe i didnt look long or hard enough. thanks anyway. i will find out by calling a local HVAC dealer.
Old 08-20-2011, 06:47 AM   #4
An old Tradesmen
Rewards Points: 7,816
Return air filter grilles, are measured by their inside dimension, where the filter goes.
The site posted above, has links to the dimensions and specs of the grilles.
noisy blower / filter box redo BlueBSH HVAC 13 07-14-2011 10:15 PM
cost to replace return boot and filter box..... BlueBSH HVAC 5 08-06-2010 08:50 AM
Noises (singing and rumble) at main return grille John_W HVAC 1 01-28-2010 04:40 PM
Loud air return grille - suggestions? chrisd HVAC 6 02-17-2009 03:25 PM
Return Air Grille Size...? ssporty21228 HVAC 4 08-17-2008 10:00 PM
