Return Air Duct Sizing Concern - HVAC - DIY Chatroom Home Improvement Forum
Old 06-29-2009, 01:16 AM   #1
Return air duct sizing concern
I had a new HVAC system installed last year with I believe a 5 ton AC unit. The home is 2200sq ft. I have two return air ducts that are non-flex 10'' ducting. One is located pretty close to the unit, the other is way on the other end of the house. Both units whistle on and off when the AC or HEAT is on.
The AC does not cycle at all. It's almost impossible for it to cool the house it will just maintain the current temp.
Is my return ducting too small? How big should they be? Is 2 enough?
Last edited by amdspitfire; 06-29-2009 at 09:27 PM. Reason: It's a 5ton not a 3.5!
amdspitfire is offline   Reply With Quote
Old 06-29-2009, 06:45 AM   #2
An old Tradesmen
Rewards Points: 6,892
2-10" are almost big enough for 2 tons.
A 12 and a 14" or 2-14" round return ducts. Plus you need the return grilles to be big enough.
Old 06-29-2009, 10:19 AM   #3
Should I stick to the metal piping and not flex?
Is this good? Will the "silent" ducts help for return ducts?
http://americanhvacparts.com/Merchan...xibleinsulated
Old 06-29-2009, 11:17 AM   #4
Do I need something like this "return air can" against the ceiling, then to an elbow then duct?
http://www.theductshop.com/shop/2525...urn-p-297.html
Old 06-29-2009, 03:02 PM   #5
sktn77a's Avatar
Rewards Points: 392
Can you fit a 14" flexduct where your existing 10" aluminum duct is? If so, use 2 of these. Flex duct has more resistance to airflow than smooth aluminum but 2 14" returns should be sufficient.
This may or may not improve your cooling performance but should get rid of the whistling and allow the blower to work within its design specs.
sktn77a is offline   Reply With Quote
Old 06-29-2009, 03:46 PM   #6
Yes, there is a good amount of room in the attic to fit bigger ductwork.
Old 06-29-2009, 05:36 PM   #7
An old Tradesmen
Something simular to that return can will help.
BUt, get it insulated. It helps to keep noise down.
Old 06-29-2009, 05:36 PM   #8
An old Tradesmen
You can use metal or flex.Either one will be find. Flex won't transmition noise as much as metal.
Old 06-29-2009, 09:29 PM   #9
So it's a 5ton unit not 3.5 like I originally thought. Theres two 11-12inch return air ducts right now.
What size should I take it up to based on this new info?
Old 06-29-2009, 09:33 PM   #10
An old Tradesmen
2-14"
Duct sizing C44 HVAC 3 03-23-2009 04:24 PM
question on return duct familyman HVAC 13 01-25-2009 11:05 AM
Return duct "boot or no boot" ads67 HVAC 16 01-10-2009 09:38 AM
Need help Duct Sizing. Cyon HVAC 2 07-23-2008 08:15 PM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 03:22 PM
