Return Air In Bsement. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-24-2009, 11:40 AM   #1
Return air In Bsement.
I am trying to put a return air vent in my basement of my 3 year old home. The house is 1500 square ft. The return air vents on the main floor are in the ceiling, and I don't know how I will tap into them? Do I even need to put them in the basement?
cambishop is offline   Reply With Quote
Old 10-24-2009, 06:51 PM   #2
An old Tradesmen
Rewards Points: 6,074
Are you going to heat the basement?
Old 10-24-2009, 10:19 PM   #3
Yes I will heat
Yeah, I am going to heat and air condition.
Old 10-24-2009, 10:20 PM   #4
Yes I will heat
I am planning on heating and air conditioning the basement.
Old 10-25-2009, 03:19 AM   #5
An old Tradesmen
Don't tap into the same ducts that the first floor uses.
Run a separate duct for the basement supply and return.
Basements take very liitle to cool them. And not a whole lot more to heat them either.
Run a separate supply trunk, with a damper in it, so you can close it down in summer, so you don't freeze out the basement.
If you tap into the first floor trunk lines. As soon as the blower shuts off. The heat from the basement goes to the first floor. And the coldest air from the first floor falls to the basement.
Basement return air ducting - flex or metal? BasementVirgin HVAC 5 10-29-2009 01:01 PM
Should I have let the ac guy close off a return? windowman3 HVAC 4 09-13-2009 09:23 AM
return air honola HVAC 11 08-13-2009 08:41 AM
Enough Return Air? mjbxx HVAC 3 02-12-2009 07:26 PM
