Old 04-29-2010, 12:06 PM   #1
Return air for the basement
I need to install a return air register for my bassement. The part I'm unsure of is the fresh air for the cumbustion for my furnace and hot water heater. Right now its the entire basement. I guess this space is really not conditioned yet. But where do I pull fresh air when it is finished. I can't put a return air grate for the utility room from the finished space can I?
swoop is offline   Reply With Quote
Old 04-29-2010, 12:41 PM   #2
An old Tradesmen
Yes, you can install grilles to let the furnace and water heater pull combustion air from the finished space.
Old 04-29-2010, 01:31 PM   #3
Thank you.
Old 01-17-2011, 09:36 PM   #4
Hi,
Where do the grilles need be located upper of lower part of the wall?
gribouille is offline   Reply With Quote
Old 01-18-2011, 05:14 AM   #5
An old Tradesmen
Need 2, 1 upper within 12" of the ceiling, and 1 lower within 12" of the floor.
Basement return air ducting - flex or metal? BasementVirgin HVAC 5 10-29-2009 01:01 PM
return air honola HVAC 11 08-13-2009 08:41 AM
Enough Return Air? mjbxx HVAC 3 02-12-2009 07:26 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
