Return Air In The Basement - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 08-24-2013, 03:14 PM   #46
Rewards Points: 45
Originally Posted by beenthere View Post
A return is only needed, if you have a supply in the basement.
Got it. Since I have two small 6 by 6 inch supply registers in the basement, I need to put a small return there. How big the return should be?
Thanks a million!
kgkg is offline   Reply With Quote
Old 08-24-2013, 03:46 PM   #47
An old Tradesmen
Rewards Points: 8,170
I would probably close off one of the supplies. And put 1-6" return in. With a damper in the return to close it down, if need be.
Old 08-24-2013, 07:57 PM   #48
Rewards Points: 45
Thank you!
Basement return duct jagmandan HVAC 5 05-29-2012 09:18 PM
cold return and heat vents in basement gaetz1 HVAC 1 02-24-2011 07:56 PM
Return air for the basement swoop HVAC 4 01-18-2011 04:14 AM
basement causing suction on basment door BlueBSH HVAC 3 06-08-2010 02:26 PM
Basement return air ducting - flex or metal? BasementVirgin HVAC 5 10-29-2009 12:01 PM
