Old 06-15-2012, 08:19 AM   #1
Return Air
Hello All,
I have a 48MBXB-HW Air Handler by First Company. It heats and cools my main house.
The previous owner sent 2-6 inch heat runs to the enclosed porch which is only connected to the home by one doorway. The return air is in the center of my house.
My problem is, is that the previous owner sent heat runs to a room with no return air. Can I "tap" off the main trunk return air line or with this cause problems with the air handler?
My system does not have separate return air lines in each room, it just relys on one large return air in the center on the home (ranch house).
Thanks for any help you can provide. I just don't want to make the situation worse.
Dano16 is offline   Reply With Quote
Old 06-15-2012, 08:41 AM   #2
I'm Your Huckleberry
Return Air
Yes, you can add as many and as much return air (ducts) as you want with only improving the systems performance.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 06-15-2012, 10:39 AM   #3
Return Air
Is the rule of thumb for a 6" heat run you need a 6" return air? That would seem most logical to me anyway.
Old 06-15-2012, 12:14 PM   #4
Return Air
Might want to install a transfer grill instead. Say a 6x30 so the air can get back to the central return.
Do I need this cold air return, pictures shown steffen707 HVAC 8 01-18-2012 03:39 PM
Looking for return noise help BlueNote HVAC 1 06-11-2011 11:06 PM
Moving Return Vent Upstairs Rowhousefix HVAC 0 08-11-2010 03:39 PM
Should I have let the ac guy close off a return? windowman3 HVAC 4 09-13-2009 09:23 AM
return air honola HVAC 11 08-13-2009 08:41 AM
