Retrofit Pump On Gravity Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 07-31-2009, 12:10 AM   #1
retrofit pump on gravity boiler
I would like to remove the old cast pipes feed two radiators in from a gravity feed heating system. My question is, can you attach a pump to some or all lines running off the boiler? My belief is that an old gravity feed boiler wouldn't have the heat transfer capacity to heat moving water thus rendering the system useless or terribly inefficient.
I want to raise the pipes, which run through a hallway and laundry room, into the ceiling with wirsbo. I believe it would be difficult to maintain a consistent incline, which indecently, the current pipes don't adhere to all that well, so I would like to add a pump to that line, or if necessary, all lines to keep heat flowing to these radiator.
Can this work or not
InquiringMind is offline   Reply With Quote
Old 07-31-2009, 05:11 AM   #2
An old Tradesmen
Rewards Points: 8,142
It can work.
Be carefull not to run too small of a pipe.
You need to match the circ to the piping restriction, and boiler BTU.
Old 07-31-2009, 08:31 AM   #3
cool, would the pump need to be installed to the entire system or can it be installed to the one loop that's being modified leaving the others gravity fed. If it's installed to the modified loop alone, is a check valve or something requred and where would it be inserted, return side of other loop(s)?
Old 07-31-2009, 02:20 PM   #4
An old Tradesmen
The whole system needs to use the circ, if its all controled by the same thermostat.
You can use a circ wiha built in flow check,
Circulation pump on boiler uncleneiler Plumbing 4 06-22-2010 09:01 AM
A 3 ton Heat Pump Retrofit Thread zootjeff HVAC 15 06-19-2009 11:37 AM
Boiler circulating pump question timothy918 HVAC 3 12-04-2008 04:14 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
Whine from a boiler pump? formarley HVAC 2 09-26-2006 07:56 PM
