Retrofit Insulation - HVAC - DIY Chatroom Home Improvement Forum
Old 10-08-2008, 01:07 PM   #1
Retrofit Insulation
Here is my dilemma. I have an addition to my house. It is insulated, but it seems to be some fibrous type of material (I'm thinking rock wool). The problem is I'd like to upgrade to a higher R-Value, but not sure how to do this. I guess one option is to rip out the existing wall board and hang new batts. option 2 would be to blow in cellulose. I like option 2 (no real drywall repair), but how do I do this when the cavity is already filled? I am thinking that the blown in insulation won't be heavy enough to compress the existing insulation in the cavity.
darkman32 is offline   Reply With Quote
Old 10-08-2008, 02:12 PM   #2
Several things here.
First off blow in rock wool has a very high R rating. It is about 3.5 per inch. So a 3 1/2" wall would have a rating of 13. This is comparable to fiberglass in 3 1/2 inch wall of R11,13 or 15 (much more expensive for R15 which is really mineral wool).
Second is that insulation needs to be fluffed up. Compressing it will decrease the insulating properties.
A good example is a down sleeping bad. I used to do a lot of mountain climbing and had a 3 1/2# down sleeping bag. When compressed I would get cold at 40 degrees but when fluffed up I could be warm at -40.
I see people who have figured that they would get extra insulation by shoving in 2 bats of R11 thinking they would get R22. Wrong, they probably got R4 if they were lucky.
What you propose is long on work and expense and short on results.
The only issues is that blow in insulation does settle over time and adding to the top might not be a bad idea if you are sure that it is settled. This is why the standard is the fiberglass that will not compress when attached to the batting.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 04:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
