Retrofit Furnace Fan Rewiring - Help - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-13-2013, 08:17 AM   #16
Rewards Points: 93
excellent! thanks! so the cool down is always with HI speed. that's exactly what I need.
Now where can I get me some of these relays in Montreal, Canada! eh!
tls1 is offline   Reply With Quote
Old 10-13-2013, 08:22 AM   #17
Rewards Points: 93
im looking on the Honeywell web site...there are quite a few R8222D relays...
customer.honeywell.com/en-US/Pages/Category.aspx?cat=HonECC Catalog&category=R8222&catpath=1.2.35.2.1
which is the correct one?
thanks!
terry
Old 10-13-2013, 09:01 AM   #18
An old Tradesmen
Rewards Points: 6,826
You want the R822D that is a 24 volt coil. double pole double throw.
Old 10-13-2013, 10:09 AM   #19
Rewards Points: 93
the ones from Honeywell have 24VAC coil rating...fine!
But some say "12 VA General Purpose Relay with DPDT switching action" and others say "Gen. Purpose Relay W.DPDT Switching" but their both 24V coil... is there a difference?
Thanks a lot!
Terry
Old 10-13-2013, 10:16 AM   #20
An old Tradesmen
Both the R8222D-1014, and the R8222D-1006 have 12 amp at 120 volt contact rating. So which ever you get will work.
Old 10-13-2013, 10:29 AM   #21
Rewards Points: 93
thanks a lot!
Nordyne furnace, error code: Pressure switch stuck closed. javagrendel HVAC 21 03-25-2013 01:14 PM
Moving furnace & redoing ducting cbrc5eric HVAC 0 02-09-2012 08:13 AM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Rewiring furnace electrical circuit BlueBSH HVAC 4 09-21-2010 01:34 PM
Retrofit OLD Lenox furnace? fbudworth HVAC 2 11-14-2006 06:01 PM
