Resize Supply Plenum In Basement. - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2011, 06:47 PM   #1
Resize supply plenum in basement.
Is it possible to have someone re-size my main air supply plenum so I can get more height in my basement? My basement height now is only 81" as it is and the plenum is 8"x16" and is 22 feet long.
Even if it was moved to the outer wall it would be fine. However, this would require a 90 degree bend to get it there because the furnace is on the opposite wall. I assume this would restrict air flow.
Any ideas or options?
Sierevello is offline   Reply With Quote
Old 12-26-2011, 06:57 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Id say find a local tinner to size it for you
plummen is offline   Reply With Quote
Old 12-27-2011, 11:09 AM   #3
REP
A 90 degree bend will be less restrictive than thinning the duct to say 6" deep.
16x8 sounds very small,how many and what size runs do you have coming off of it?
How big a house do you heat and cool and what size furnace and a/c do you have?
REP is offline   Reply With Quote
basement flooring suggestions? jeffro83 Flooring 2 05-14-2011 12:58 PM
Plumbing in Basement osajia Plumbing 7 12-08-2010 12:00 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 09:21 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
