Residential Central Air 2 Units Up/down Stairs - HVAC - DIY Chatroom Home Improvement Forum
Old 06-14-2011, 03:58 PM   #1
Smile
Residential central air 2 units up/down stairs
The the thermostat upstairs is set for 86 (not up there a lot) thermostat reads 96; thermostat has green light on and closet fan coil is running; started looking around and noticed condenser outside was not running. Have a home owners AHS service policy; someone will come tomorrow but I am wondering is there anything I could do to reset condenser. I tried to apply my knowledge of a/c to this problem but I don't need to create another problem. Thanks!!
wellsc1926 is offline   Reply With Quote
Old 06-14-2011, 07:37 PM   #2
Rewards Points: 1,560
I'd shut down the upstairs unit since your outside fan isn't running.
bob22 is offline   Reply With Quote
Old 06-14-2011, 09:03 PM   #3
Did shut unit off but would it help if I turned on the fan mode of thermostat and also what could cause this. House built in 2005 carrier 1.5 ton unit Thanks. Anything I could reset??
Moving Outdoor Central A/C Units 99altrade HVAC 6 12-21-2010 02:42 PM
Replace Windows Units with Central AC 2286743 HVAC 2 08-24-2009 07:56 PM
are central air units compatible with any furnace? firsttimeowner HVAC 3 08-10-2009 09:15 AM
central air vs window units sharonjo General DIY Discussions 6 07-22-2009 09:37 PM
Two Central units TazinCR HVAC 5 09-07-2008 12:50 PM
