Residential Air Handler In Modular Home. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 07:51 PM   #16
I'm Your Huckleberry
Rewards Points: 2,270
Originally Posted by beenthere View Post
I meant the new air handler you installed. Its designed for return to come up from the bottom of the coil. You said no duct work under it.
On that particular one I'm going to have to add a return run and grill this week sometime. It's going to be on the floor, obviously, in the living area.
Right now it's choked off to the floor.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-22-2012, 07:52 PM   #17
An old Tradesmen
Rewards Points: 6,098
So do you gotta go back now and get return to that new modular air handler?
Old 04-22-2012, 07:54 PM   #18
An old Tradesmen
LOL... You posted as I was writing my other post.
Old 04-22-2012, 07:56 PM   #19
Now that you mention it I didn't need a filter rack either. This is emarrassing.
I told the guy we shouldn't be putting this thing in there but we had to have it done this week. Ordering all the equipment from Ohio would've take about a week in itself, putting us behind.
Now I'm shooting myself in the foot and regretting installing it altogether, the never ending nightmare.
Thanks.
Old 04-22-2012, 07:57 PM   #20
An old Tradesmen
Yep, I've been there.
Old 04-22-2012, 07:59 PM   #21
I should've just had a custom return plenum made for the air handler to sit on, cutting the front out like a vertical closet unit. Maybe I'll just do that instead of having to crawl around and cut the floor up.
Ack.
Thanks.
Old 04-22-2012, 08:01 PM   #22
An old Tradesmen
Of course you would need to redo teh line s and drain line if you raise the air handler to put a big enough return air box/plenum under it.
Old 04-22-2012, 08:05 PM   #23
Not only that, but I'll be needing to shorten the supply plenum. I really didn't think this through.
Live and learn, I guess. Say you doing anything this week? I have a residential electrical air handler in a modular home that needs some work done to it...
Thanks.
Old 04-22-2012, 08:19 PM   #24
Rewards Points: 614
oh my
carmon is offline   Reply With Quote
Old 04-22-2012, 08:49 PM   #25
An old Tradesmen
ROFL.
I'll let you have that redo fun.
Old 04-22-2012, 10:39 PM   #26
16" x 20" is the filter rack filter size which is specific to the 3 ton system but isn't that only half of what's needed? 25" x 25" would allow 1250 cfm.
16 x 20 = 320 (gross total area) x's 2 (cubic feet per square inch) = 640cfm. Why would they give such a small size filter and rack? Just to match the cabinet size of the air handler?
25" x 25" = 625 x's 2 = 1250. 3 ton system @ 400 cfm per ton requiring 1200 return cfm minimum.
Thanks.
Old 04-22-2012, 10:48 PM   #27
AKA HVACTECHFW
Rewards Points: 1,208
you are correct... They use that size to match the cabinet. In order to use that size you need a $1 filter that captures nothing.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-22-2012, 10:53 PM   #28
That's what I use on my own home. I just want to catch dog hair and dirt, just the big stuff, without restricting any air flow.
Thanks.
Thanks.
Old 04-23-2012, 11:19 AM   #29
Good news! I was about to go and rip out off the newly installed "old" equipment, ordering the correct equipment from Dallas to install, but was told the home is being moved (possibly torn down) and to leave it.
That's a brand new modular home, never been lived in and it's already being destroyed and I just installed a brand new hvac system. I think someone bought the land and is building a regular home, not on bricks.
Next time though I'll have the right equipment.
Thanks.
Old 04-23-2012, 05:56 PM   #30
I still can't believe it, all that money just out the window.
And that's pretty decent equipment, too. New trash, I guess.
Thanks.
1938 TN Home - My First Home, My First project, Tons of Pictures!!! Firefighter3244 Project Showcase 78 07-01-2014 11:55 PM
modular home flooring problem wen Flooring 1 08-15-2005 02:11 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
