Residential AC Condensate Drain By Gravity. - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 03:24 PM   #31
Originally Posted by StudentGUY View Post
If I remove the Trap and put the hoses directly in the PVC pipe everything works fine, but then I get sewage smell coming from the pipe, that is why I fitted the trap.
sorry to say you will get sewer smells in your home via the drain tube.
You have a very illegal set up there. The code requires all drains go to a sanitary drain for an ac, not a soil drain.
hvac5646 is offline   Reply With Quote
Old 01-24-2012, 04:20 PM   #32
Originally Posted by hvac5646 View Post
[/b][/i]
As this is an apartment, there is no sanitary drain there at all. Even the drains in the floor tiles (bathrooms) are connected to the same soil drain.
That is why I fitted the trap, so I would not get the smells up my rooms
StudentGUY is offline   Reply With Quote
Old 01-24-2012, 04:23 PM   #33
Originally Posted by Tator1076 View Post
It all depends on how much a load the a/c is in. That outdoor and indoor temp.
Lets say outdoor 30C and indoor 22C.
Ac unit is this size:
Old 01-24-2012, 06:07 PM   #34
No win situation for you- if you don't want to use a condensate pump.
You are about the only guy I have seen who was savvy enough to use a trap
Old 01-25-2012, 04:00 PM   #35
HVAC Tech/ Browns Fan
Good luck buddy!!!
Tator1076 is offline   Reply With Quote
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 10:40 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Air Conditioner Condensate Drain djchase88 Plumbing 8 08-28-2009 06:32 PM
