Residential AC Condensate Drain By Gravity. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 06:11 PM   #16
1. get rid of all the "hoses and clamps"
2. run every thing in 3/4 (or bigger) pvc
3. traps at the evaporator coils with mechanical fittings so they can be cleaned....put vent " T" right after traps
4. problem solved........thats if you follow what i have just told you.
good luck and have a nice day.
harleyrider is offline   Reply With Quote
Old 01-23-2012, 06:16 PM   #17
Was thinking of fitting the 3piece in the location I have painted, and running a hose until the ceiling. What do you think?
StudentGUY is offline   Reply With Quote
Old 01-23-2012, 06:18 PM   #18
If it would be that simple, unfortunately all the walls are sealed up allready, and taking them apart will cost big $$$
Old 01-23-2012, 06:30 PM   #19
I'm Your Huckleberry
Rewards Points: 2,270
Where were the old drains from the a/c evaporator going to and what material was used as the drain?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-23-2012, 06:44 PM   #20
This is a new installation, there where no previous pipes. And as the build was allready completed, the AC was added on a later stage.
Old 01-23-2012, 06:49 PM   #21
An old Tradesmen
Rewards Points: 6,876
Originally Posted by Tator1076 View Post
Utilitech 1/8-HP Thermoplastic 58 GPM Condensate Pump
Item #: 313500 | Model #: 59907-UTL1
A bit much for an A/C.
Old 01-23-2012, 06:50 PM   #22
HVAC Tech/ Browns Fan
I think you are better off the way I say before.
Tator1076 is offline   Reply With Quote
Old 01-23-2012, 06:52 PM   #23
I know I was looking for little giant on lowe's. I was just showing him use a pump of some kind
Old 01-23-2012, 06:54 PM   #24
Old 01-23-2012, 06:55 PM   #25
Here we go sorry
Old 01-23-2012, 06:56 PM   #26
Too bad. Call a gc to have a drywall crew come rip the walls out so you can do it to code. There is no other option. It was dumb on the builder's part to add a/c after the fact.
You might be able pipe it to the outside to a French drain. Check your codes, call your city's mechanical inspectors office.
Thanks.
Old 01-23-2012, 06:58 PM   #27
I agree. That looks like crap
Old 01-23-2012, 07:12 PM   #28
http://www.checkthishouse.com/15/dri...ning-coil.html
Thanks.
Old 01-24-2012, 02:03 PM   #29
Today I changed the trap to a vertically mounted trap with an open top, and just tugged the hoses in it. Water is draining fine now, and should be no problem.
Can anyone advise how many liters per hour does a Residental AC unit produce?
Old 01-24-2012, 02:12 PM   #30
It all depends on how much a load the a/c is in. That outdoor and indoor temp.
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 10:40 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Air Conditioner Condensate Drain djchase88 Plumbing 8 08-28-2009 06:32 PM
