Rerouting / Reconfiguring Vents For Kitchen - HVAC - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 12:54 AM   #1
Rerouting / Reconfiguring Vents for Kitchen
Hello,
I am working on a remodel and due to some framing issues, the existing supply duct to my kitchen can no longer reach its prior location with the same size duct due to the installation of a new beam. The system is relatively new. Previously the area (including the laundry room) was serviced by a single 7" supply line and a single 6" x 10" register.
I can come up with two possible ways to re-route the supply. 1) Either run the ducts into a new soffit along side the new beam in order to provide air/heat to the kitchen area. I would not be able to access the laundry room from the soffit, so it would be in conjunction with option (2) which is to reduce the duct size and access the kitchen and laundry (or just laundry in conjunction with option (1)) through a roughly 5" notch that I am allowed to take out of the beam.
If I go with the soffit to service the kitchen part, it will be about 20" feet long. My thought was that adding 2 new registers and directing them towards the kitchen was probably the way to do this. The laundry will just requite one small register (serviced by 4"?).
I do a lot of work on my house but have not done much in the hvac department. Any tips or tricks to get the air back into the new kitchen and laundry space based on the above constraints?
Thanks in advance!
rustlerski is offline   Reply With Quote
Old 02-24-2013, 04:40 AM   #2
An old Tradesmen
Rewards Points: 6,548
Might want to go with a 5" to the laundry for cooling if you want the temp in it to be close to the rest of the house.
Run along side the beam for the kitchen.
Old 02-24-2013, 02:25 PM   #3
Would you also reduce to 5" for the kitchen runs within the soffit?
Old 02-24-2013, 04:20 PM   #4
An old Tradesmen
No, 6 inch min. How well did it keep the kitchen cool in the past with the 7" line serving both rooms. If it didn't, then make it a 7". You can always throttle it down later. can't throttle up an under sized run.
Old 02-24-2013, 09:54 PM   #5
It cooled the kitchen fine previously. The register was mounted in the side of the kitchen right above the door into the laundry room so the laundry was only tangentially served. Now that I have to reconfigure the line, I was going to add a dedicate register to the laundry. I will do my best to get two 6" supplies into the soffit for the kitchen and a 5" over to the laundry. Thanks.
Have Gable/Soffit Vents Contractor Suggest Ridge Vents sallygump50 Roofing/Siding 3 05-11-2012 11:56 AM
Ridge vents, soffit vents, end gable vent confusion. joemill Roofing/Siding 4 04-01-2012 06:18 PM
ridge vents vs. box vents vs. turbine vents redaws Roofing/Siding 12 03-12-2012 10:48 PM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 11:13 AM
Atic: Adding Intake and Exhaust Vents (Maybe Ridge) arcane Roofing/Siding 9 07-22-2010 07:20 PM
