Rerouting HVAC Ducting For An Upflow Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 06:29 PM   #1
Question
rerouting HVAC ducting for an upflow furnace
Hello, please advise on my ducting situation on 1500 sq ft single level home.
Current setup:
20+ year old gas furnace in garage and AC unit outside. Unit seems like on last leg and near end of service life. Downflow unit, ducting goes through crawlspace into floor vents. Air return/filter is in hallway ceiling going through attic back down into garage onto top of furnace.
Crawlspace is a nightmare. Only about 2 ft of clearance and with HVAC flexduct running all over down there its very hard to move around. Crawl has gotten wet and I'm in the process of fixing drainange issues with the property and in the crawl space as well as deal with rats that may have compromised the flex duct.
What I would really like to do is get a new upflow furnace installed or a heat pump and run new insulated ducting up into the attic and into ceiling vents to stay out of the crawl. Is this advisable? I want to keep the furnace or air handler in the garage and just run insulated duct up into the attic. Would vents in the ceiling only cause problems as opposed to having them in the floors? Could I have the vents in the ceiling and also keep the return in the ceiling, or would I have to put the return down the wall to get it closer to the ground?
Thanks for any advice!
joregon3597 is offline   Reply With Quote
Old 05-03-2012, 06:37 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Yes it's possible and more than feasible. Costly, but appropriate.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-03-2012, 07:08 PM   #3
You can also have a horizontal system installed in the attic itself.
Thanks.
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Moving furnace & redoing ducting cbrc5eric HVAC 0 02-09-2012 08:13 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 03:27 AM
