Repositioning Hot Water Baseboard Piping - HVAC - DIY Chatroom Home Improvement Forum
Old 11-19-2009, 02:15 PM   #1
JPM
Bill Traver
Rewards Points: 101
Is it possible to create a secondary loop in hot water baseboard heat? In other words, I am thinking of putting in a "T" to the current set-up to add a section of heat piping to a wall that currently does not have it. Right now the piping is making a turn on an inside wall and I would like to also continue into the next room along the outside wall.
Sorry, I hope this is clear enough, I could not figure out how to add either pictures or drawings.
JPM is offline   Reply With Quote
Old 11-19-2009, 03:59 PM   #2
An old Tradesmen
Rewards Points: 7,816
Can't tell much from your drawing.
If you tee off a baseboard. Then you decrease teh amount of water that was flowing through the original baseboard.
Old 11-20-2009, 08:08 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,636
Ayuh,.... I'd think you'd be happier with the results it you elbow off to the new run,+ then double back to elbow back in where you took off...
That way you still have a postive flowable loop...
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Water pressure and Pex piping mainstreetprod Plumbing 12 01-25-2009 09:12 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Baseboard Hot Water radiators hotdiggitydog HVAC 2 04-24-2006 11:27 PM
