Replacing Wire Inside Ac Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 07-30-2010, 03:24 AM   #1
replacing wire inside ac unit
I had a fire inside an ac unit. Almost all the wires and capacitor are burned. I can see where the fire started from a wire arcing against the metal. All the wire in this ac unit seems to be aluminum wiring. I bought thwn wire that is rated higher than the aluminum wire and I even bought the correct colors and new connectors. My question is, will thwn wire be ok to use inside the unit? I cant think of any reason why It wouldnt be. The only thing I can think of is maybe the aluminum wire is used because of the vibration?
kevinv is offline   Reply With Quote
Old 07-30-2010, 04:12 AM   #2
Another question
Also, one more question. Have you guys ever used a hard start kit in place of a ptcr?
Old 07-30-2010, 06:27 AM   #3
An old Tradesmen
Rewards Points: 6,498
Aluminum wire was used to save money.
You can use a hard start in place of a PTC.
The Following User Says Thank You to beenthere For This Useful Post:
kevinv (08-03-2010)
Can portable AC unit intake air from inside room? bludshot HVAC 20 05-13-2010 05:41 AM
Basic wire needs for replacing my AL branch wiring tigereye Electrical 16 12-03-2009 09:52 PM
Low Voltage Wire Shorting Rdakota06 Electrical 3 07-22-2009 02:15 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Replacing old wire in finished walls/ceilings JRoot Electrical 10 03-27-2008 04:47 PM
