Old 03-31-2010, 10:49 PM   #1
Question
Replacing Trane XL90 Vent Inducer
I have a Trane XL90 (TUX080R942V2) with a noisy vent inducer (it vibrates as the speed ramps up & down and induces vibrations in the cabinet). Trane tells me a replacement kit is available which includes the vent motor/blower, a new circuit board and wiring. I'm not a HVAC guy but installed the furnace myself and am pretty handy with electrical/electronics and mechanical things.
This replacement kit is supposedly quieter than the original and contains a different type of motor and speed control circuitry so I am considering doing it.
Am wondering though if this is a DIY project or if special instruments or tools are needed?
Any advice or suggestions would be appreciated.....
NoSmoke is offline   Reply With Quote
Old 04-01-2010, 09:52 PM   #2
sktn77a's Avatar
Can't help you with your specific problem but I can relate a similar experience with the very first single stage XL90 I had installed 25 years ago! The vent motor wailed like a banshee, too. The local Trane rep came out and agreed it was noisy and said they "have a new circuit board that makes it quieter". Well, they didn't replace the inducer motor so it was just as noisy, but they did replace the board which reduced the purging time from 2 min to 30 seconds. After that the main blower kicked in which masked the noise of the inducer fan.
"The more things change, the more they stay the same!"
Keith
sktn77a is offline   Reply With Quote
Old 04-01-2010, 11:39 PM   #3
retired elect/hvac/plumb
plummen's Avatar
easy job,make sure to install new gasket between inducer motor and heat exchanger
plummen is offline   Reply With Quote
Old 04-02-2010, 01:19 AM   #4
Keith
Heh, I guess that would help alright. I haven't measured it but the purge time on my unit seems like about 30 seconds (most of the time) but even that seems more than long enough. As you point out, the blower m/l masks the inducer noise (but not entirely in my case). The new "kit" contains a new style inducer motor so hopefully it is quieter (at least that's what the local Trane rep tells me).
Old 04-02-2010, 01:22 AM   #5
Thanks, I think I'll go for it (but after the heating season ends in case something goes haywire).
Do you know if the kit has the new gasket? Is there anything I would need that the kit does not contain?
Old 04-02-2010, 05:14 PM   #6
plummen's Avatar
it should come with one of those fuzzy gaskets
Attic Ventilation Question handy man88 Roofing 10 02-12-2010 11:50 PM
Shingling over ridge vent -details needed jogr Roofing 4 11-06-2009 06:47 PM
Trane xl90 Combustion blower Issues bjpaff HVAC 3 12-18-2007 11:00 PM
trane furnace with inducer blower error tjh57 HVAC 1 10-22-2006 08:45 PM
