Replacing Thermostat, No Heat (heat Pump, 2 Stage Heat, 1 Stage Cool) - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-27-2011, 08:47 PM   #16
Dude. You HAVE TO HAVE THE JUMPER IN.
A group of hvac professionals are telling you how to fix it..do it!
Master of Cold is offline   Reply With Quote
Old 09-27-2011, 09:21 PM   #17
JJboy's Avatar
Let me drawing to you.
Replacing thermostat, no heat (heat pump, 2 stage heat, 1 stage cool)-rh-rc.jpg
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
Doc Holliday (09-27-2011)
Old 09-27-2011, 09:43 PM   #18
An old Tradesmen
Rewards Points: 7,776
Yep, they don't work in heat mode without the jumper from RC to RH.
Old 09-27-2011, 10:17 PM   #19
Yes, I understand that, and that's exactly what I did. Everything works as expected now, so I am happy. Thanks all for the help!
I'm also happy to know that the instructions do not clearly indicate to do this for my system, at any point, so this issue was never the fact that I can not clearly interpret instructions.
No drawing necessary, but thanks...
BrianJM is offline   Reply With Quote
Old 09-27-2011, 10:30 PM   #20
Old 09-28-2011, 09:53 AM   #21
Rewards Points: 6,652
That would be because they put the jumper between W1 & E, but most likely did not read completely through the instructions, and just flipped back to page 74.
Hunter Thermostat Model 44860 Heat Pump Emergency Heat Does Not Work On Auto stvnhdmpa HVAC 8 12-08-2010 05:44 PM
heat pump cut off set point oldswab HVAC 4 12-02-2009 02:09 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 10:07 PM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 10:28 AM
programmable thermostat + heat pump Potomac101 HVAC 10 12-03-2008 10:02 AM
