Old 10-29-2012, 02:11 PM   #1
Unhappy
Replacing thermostat need a little help
Hi
I am replacing my old (non-programmable) thermostat for the first time. Here is a picture of the wires http://oi49.tinypic.com/el4jg4.jpg. (notice the blue wire is in the RH spot.)
This is the new (programmable) honeywell RTHL2310/RTHL221 thermostat http://oi45.tinypic.com/28l9t38.jpg
I am not sure where to put the blue (RH) wire in the new thermostat.
Any help will be appreciated.
Thank you.
Edit: Now I am having problems trying to program the day of the week for the system.
Instructions say:
1. Press the SET button then press ^ or v to set the clock time. (Works for the clock)
2. Press the SET button, then press ^ or v to select the day of the week. (The problem here is, when the clock is on the correct time I press SET again and it goes to scheduling the Time and Temperature for the schedule(with no day selected therefore I can't program it past a day as it currently is), it never gives me an option to set the day of the week.
3. Press RUN to save & exit.
I have tried holding the SET button and various other things, but nothing has gotten me to a way to set the day.
If needed I can post a picture of the front of the thermostat.
DIYnewbees is offline   Reply With Quote
Old 10-29-2012, 02:47 PM   #2
DIY Enthusiast
sublime2's Avatar
Think its gonna be the R spot on the new T stat.
Rest go to colors as indicated.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
DIYnewbees (10-29-2012)
Old 10-29-2012, 07:49 PM   #3
remove jumper between r and rc
HVACTECH96 is offline   Reply With Quote
Old 10-29-2012, 07:50 PM   #4
red to rc and blue to r
Tags
honeywell, thermostat
Replacing Honeywell T8401C thermostat sktn77a HVAC 4 10-07-2012 06:28 PM
Replacing White-Rodgers Thermostat, Help. Dallas79 HVAC 16 03-07-2012 01:11 PM
Replacing a two wire heat thermostat to a four wire cibao67 Electrical 2 03-01-2010 09:42 AM
Replacing thermostat rjaxin HVAC 2 02-23-2010 02:20 PM
replacing an old heat thermostat dstm44 HVAC 1 11-01-2008 05:55 PM
