Replacing Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2011, 08:44 AM   #1
replacing thermostat
My heat stopped working upstairs and there was no "power to the thermostat" it does not have a battery so I am replacing it. My question is the wiring. The old one had a wrap around from W2 to E (both posts). The new thermostat has single entry post with no way to wrap the the wire around 2 post. The instructions say to run the jumper from w2 to e. My question is do I run the jumper and then also run w2 wire into w2 so that I would have 2 wires in w2 the one from the electrical and the jumper? Thanks.
Pbutts29 is offline   Reply With Quote
Old 01-04-2011, 09:05 AM   #2
Also the old thermostat had Y in the Y post. This thermostat has Y1 or Y2.. Which one would I use? My assumption would be y2 Like w is in W2. Y is Compressor stage 1 or 2 . Help on that would be great as well...
Old 01-04-2011, 09:27 AM   #3
help.. thermostat replacement
Old thermostat says y.... New thermostat has Y1 and Y2... Which one do I use????
Old 01-04-2011, 01:51 PM   #4
Rewards Points: 494
Look at this thread:
new thermostat wiring
Look for my userID.
See link in my post. Explains it from the internets.
diyorpay is offline   Reply With Quote
Old 01-04-2011, 02:49 PM   #5
AKA HVACTECHFW
Rewards Points: 1,208
use y1
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-04-2011, 02:57 PM   #6
AKA HVACTECHFW
jumper w2 to e and add w2 wire to w2 terminal as well. use y1 for y wire
IT IS WHAT IT IS
Old 01-04-2011, 03:28 PM   #7
An old Tradesmen
Rewards Points: 6,944
Merged your 2 threads. Please don't make duplicate threads about the same thing.
Replacing Old Thermostat with Totaline 40bill40 HVAC 1 05-14-2010 04:26 PM
Replacing thermostat rjaxin HVAC 2 02-23-2010 01:20 PM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 04:19 PM
Replacing a thermostat mnwalsh1 Introductions 0 11-08-2009 01:31 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 10:07 PM
