-   -   replacing thermostat (http://www.diychatroom.com/f17/replacing-thermostat-91264/)
Pbutts29 01-04-2011 09:44 AM
My heat stopped working upstairs and there was no "power to the thermostat" it does not have a battery so I am replacing it. My question is the wiring. The old one had a wrap around from W2 to E (both posts). The new thermostat has single entry post with no way to wrap the the wire around 2 post. The instructions say to run the jumper from w2 to e. My question is do I run the jumper and then also run w2 wire into w2 so that I would have 2 wires in w2 the one from the electrical and the jumper? Thanks.
Pbutts29 01-04-2011 10:05 AM
Also the old thermostat had Y in the Y post. This thermostat has Y1 or Y2.. Which one would I use? My assumption would be y2 Like w is in W2. Y is Compressor stage 1 or 2 . Help on that would be great as well...
Pbutts29 01-04-2011 10:27 AM
help.. thermostat replacement
Old thermostat says y.... New thermostat has Y1 and Y2... Which one do I use????
diyorpay 01-04-2011 02:51 PM
Look at this thread:
http://www.diychatroom.com/f18/new-t...-wiring-89916/
Look for my userID.
See link in my post. Explains it from the internets.
hvactech126 01-04-2011 03:49 PM
use y1
hvactech126 01-04-2011 03:57 PM
jumper w2 to e and add w2 wire to w2 terminal as well. use y1 for y wire
beenthere 01-04-2011 04:28 PM
Merged your 2 threads. Please don't make duplicate threads about the same thing.
