-   -   Replacing thermostat (http://www.diychatroom.com/f17/replacing-thermostat-65146/)
rjaxin 02-23-2010 09:49 AM
1 Attachment(s)
I recently purchased a new digital programmable thermostat to replace my old mercury one on my Carrier Weathermaker 8000
The old thermostat currently has only 2 wires running up to it and then there is a wall switch (with 2 wires) to force the fan on.
I'm not sure which wiring pattern pertains to my install:
http://icpindexing.mqgroup.com/docum...tat%20TS21.pdf
Here is a picture of the controller(?) in the furnace where the old thermostat and fan switch are connected. Ideally, id' like to run the additional wire to the thermostat as well to control the fan there rather than the separate wall switch.
rjaxin 02-23-2010 12:50 PM
OK... I think I've got it straight by reading some other threads:
I will have to run at least one more wire for this thermostat for the C (common) as it is not battery powered?
..so minumim:
T-Stat -> Furnace
C -> C (Common)
W2 -> W (Heat)
RH -> R (Power for Hot)
And if I want to manually turn on fan from thermostat rather than switch:
G -> G (Fan override?)
And if I want the thermostat to be able to run the fan as cooling based on the temp?:
RC/RH -> R (Power for Hot and Cold)
Y1 -> Y (Fan - cooling?)
So ideally I want to replace the 2-wire with a new 5-wire (and jumper RC/RH on the thermostat) or replace with a 6-wire and connect RC/RH to R on the furnace side?
rjaxin 02-23-2010 01:20 PM
Also... will there be any difference between connecting G for the fan and using the furnace's delay setting? If I connect G will the fan start immediately on a call for heat or will the delay setting still take affect? If I disconnect the delay jumper will the thermostat handle the delay?
