Replacing A Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 02-17-2010, 07:15 PM   #1
xrum's Avatar
Replacing a thermostat
i'm trying to replace an old thermostat, but the directions for the new one only have a 5 wire directions, while my old one had 6.
orange, green, blue, white 2, red and yellow 1.
the installation directions only talk about Green, Yellow, White, Rc and Rh...
someone please help
xrum is offline   Reply With Quote
Old 02-17-2010, 07:28 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,112
Do you have a heat pump? Post the make, model # of the furnace/air handler and heat pump or A/C unit.
Old 02-17-2010, 08:28 PM   #3
Your new stat is not a heat pump stat if there is no O/B terminal. That orange wire energizes your reversing valve. I suspect that if you look at the compatability chart that comes with the stat you will see that it is not capable of HP operation.
brandonmcginnis is offline   Reply With Quote
Old 02-17-2010, 09:22 PM   #4
xrum's Avatar
i have a lennox hp26 series air handler... how do i find out which one to get?
Old 02-17-2010, 10:09 PM   #5
That's a heat pump so you need a heat pump thermostat . Needs to be 2 heat /1 cool.
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
Replacing a thermostat mnwalsh1 Introductions 0 11-08-2009 02:31 PM
I need help replacing a thermostat feltdog HVAC 3 11-06-2009 07:29 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 11:07 PM
Questions about replacing a thermostat janralix Electrical 3 08-07-2009 06:29 AM
