Replacing Thermostat...................... - HVAC - DIY Chatroom Home Improvement Forum
Old 06-22-2009, 02:24 PM   #1
sktn77a's Avatar
Rewards Points: 360
Replacing thermostat......................
I have an older White Rodgers Digital Comfort Set II programmable heat pump thermostat (1F92-71) which is connected to a Rheem single stage heatpump with electric strip backup heat. The thermostat is giving up the ghost so I'm replacing it with a 1F95-1291. I have a couple of questions on the wiring:
1. The old thermostat has the white wire connected to E1 (emergency) which is jumpered to W2 (second stage heat/Aux). The new thermostat has a single connector labelled W/E (2nd stage heat aux/1st stage heat emergency). I take it they have just combined the E1 and W2 connectors into the W/E connector and I should just connect the white wire to W/E?
2. The old thermostat has the yellow wire connected to Y1 (first stage heat) which is jumpered to W1 (first stage cool). The new thermostat has a single connector labelled Y (1st stage heat/1st stage cool). Again, I take it they have just combined the Y1 and W1 connectors into the Y connector and I should just connect the yellow wire to Y?
3. The old thermostat has the blue wire connected to the B connector (changeover output, heating). I take it I should connect this to the same B terminal (changeover output, heating) in the new thermostat?
Sorry if this is basic, but I want to double check before I mess with a heat pump!
sktn77a is offline   Reply With Quote
Old 06-23-2009, 07:41 AM   #2
sktn77a's Avatar
Rewards Points: 360
Anybody............. Bueller............ Anybody???
Old 06-23-2009, 08:21 AM   #3
A Google search with that model will get you to the White Rodgers and detailed wiring instructions.
hvaclover is offline   Reply With Quote
Old 06-23-2009, 09:49 AM   #4
sktn77a's Avatar
Rewards Points: 360
Thanks: Yes, I've done that. I have the wiring diagrams from the White-Rodgers site but all they do is identify the terminals as "B", "G", "Y1", etc, but they are different for the two thermostats and neither wiring diagram says which wire to connect to which terminal (just the terminal identification).
So I guess I need a "Gestalt" that my assumptions (above) are reasonable (or not, as the case may be).
Old 09-02-2009, 08:26 PM   #5
sktn77a's Avatar
Rewards Points: 360
Originally Posted by CPERRY View Post
I have a mini fridge that is not getting cold. It is plugged in and also it is a WELBILT model number W73691.
??????? What has this got to do with the price of sliced bread ???????
Old 09-02-2009, 10:44 PM   #6
HVAC
Looks like you got the wiring right
KAVF is offline   Reply With Quote
Old 09-02-2009, 11:07 PM   #7
sktn77a's Avatar
Rewards Points: 360
No, I haven't been able to figure it out yet (and I haven't really had the time). Fortunately, it's an attic heatpump system that we rarely use, so I'll tackle it when I have a little more time.
FAULTY THERMOSTAT!!! What the He.... Krazecon HVAC 11 02-12-2009 05:26 AM
replacing an old heat thermostat dstm44 HVAC 1 11-01-2008 05:55 PM
