Replacing Square Ductwork With Rectangular - HVAC - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 10:08 AM   #1
Replacing Square ductwork with Rectangular
Hi, I'm starting a basement remodel and I'm trying to figure out what to do with the ductwork.
It's a simple system, two main ducts coming off the unit and going across the middle of the room through 10 inch square metal ducts before heading upstairs.
The problem is that my ceiling is only about 7 feet high and these suckers come down 12 inches and cause us to duck when walking through. So, I'm wondering if I can simply replace the square ducts with rectangular ducts that might buy me a few more inches of head room. Shouldn't this be simple? I'm thinking that as long as I end up with the same cubic inches of airspace in the duct, I can change the shape, right?
GCDC is offline   Reply With Quote
Old 01-09-2010, 10:46 AM   #2
Yes you can. Don't get the ratio past 3:1 or the air flow will be hampered.
Old 01-09-2010, 12:33 PM   #3
Wading through this link may prove fruitful
http://www.engineeringtoolbox.com/hv...tems-t_23.html
You don't want to be adding duct fans and other bandaids to your work, after your install.
ASHRAE literature is costly and hard to come by, but this book
http://www.amazon.com/Mechanical-Eng.../dp/1888577681
might be available in your local library. It has chapters on HVAC stuff.
You might also want to research 'register throw'.
Boning up on thermodynamics prevents gross errors.
Everyone makes minor errors.
Old 01-09-2010, 01:28 PM   #4
An old Tradesmen
Rewards Points: 7,384
You can use 8X14, or 6X18(8X14 is better).
Tags
basement , duct , ductwork , hvac , remodel
Poor Attic Ventilation Mechanically Challenged Roofing/Siding 15 10-23-2008 09:05 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
replacing rectangular duct with 6" pipes peso HVAC 4 06-05-2008 08:43 PM
roof venting via the soffit darren Roofing/Siding 8 04-13-2008 09:29 PM
replacing ductwork What have I done HVAC 7 06-02-2007 05:56 PM
